It is currently Fri Dec 19, 2025 9:24 am
Post new topic Reply to topic  [ 16 posts ]  Go to page 1, 2  Next
 Post subject: Dual Kadrons Flooding on the left fuel leaking from Exhaust
PostPosted: Sat Sep 06, 2008 8:47 pm
Gentlemen,and Ladies...
H E L P !!!!! :cry: :evil:
I purchased the 65 VW on a 64 pan with a 71 AE 1600 DP with a pair of Kadrons 40's....
The beast was acting like it had a clogged carb, so I disassembled and rebuilt them with a pair of carb kits. (First Time)
So here is the issue, I put everything back together, and I can get it running strong in the driveway, but if I take it out in the 'hood, I get hesitation, and jerking, if I open it up on the hiway, I can get through 3rd, and then 4th I loose power, and can only go about 50, running at about 3200RPMS, nothing more, can't get anymore out of it. I get home, and the lefty is flooded, spilling out of the top, worse is I have fuel coming out of my mufflers!! I was getting 6lbs of fuel pressure from the fuel pump, so I added an inline regulator to tune the pressure down to 1.5-2lbs. (I read somewhere on the net this was optimal for the Kadrons..) the right carb is fine, I read that these thing have a small bearing under the accelerator pump spray bar, but when I disassembled, there was nothing there.
there is also some type of brass plug in the bowel on the left side, that looks like you have to thread a screw into it, and then pull it out, or something???\
Don't want to jack it up, so I have not farted around with that yet, but I think the is another check valve in there too??
Thanks for everything!!!
 Post subject: Re: Dual Kadrons Flooding on the left fuel leaking from Exhaust
PostPosted: Sat Sep 06, 2008 8:57 pm
sounds like the float is stuck you may want to turn your fuel off so you dont wake up with an empty fuel tank in the morning
PostPosted: Sat Sep 06, 2008 9:15 pm
I have checked the float, and I can't see it hanging anywhere with and without fuel in the bowl.
I read that you can adjust the float, but how do you measure the adjustments??
I have added a second washer under the seat valve to lower it down towards the float, and was thing to add a third??
I am about to go mad!!! I have been at this for at least three days or more!!
THX for everything...
PostPosted: Sun Sep 07, 2008 11:06 am
I found a diagram online for ya. I'll print it out and bring it over.
PostPosted: Sun Sep 07, 2008 11:09 am
You mind posting that diagram? im rebuilding a pair of 40 Kadrons too
PostPosted: Sun Sep 07, 2008 11:34 am
I think I may already have that D, but I am willing to try anything!
I sent AJ Sims an email today, and hopefully he will have an idea.
Burk, when you open up those 40's, let me know if you see a check ball down under the accelerator pump spay bar.
PostPosted: Sun Sep 07, 2008 11:56 am
lets see some pics of this car
PostPosted: Sun Sep 07, 2008 3:41 pm
I was think about the problem. I had a similar problem. I think you might have a bad float valve. Did this problem occure after you put on the rebuild kit? If so swap your old valve back in and see if this helps your problem.
PostPosted: Sun Sep 07, 2008 3:42 pm
most likely its the needle and seat....
PostPosted: Sun Sep 07, 2008 3:57 pm
I think its because there arent any pics of it yet
