It is currently Fri Dec 19, 2025 10:46 pm
Post new topic Reply to topic  [ 28 posts ]  Go to page 1, 2, 3  Next
 Post subject: 40 horse
PostPosted: Tue Oct 07, 2008 8:01 am
Okay here's the deal:
I had my motor rebuilt about 6 months ago due to a bad oil leak from the front pulley,well it back again ! I believe my case may be to worn ? Also to try to stop the leak I put a bolt on sand seal pulley and the oil keeps a comin ? Hopefully somebody has a answer that can sovle my problemo. Thanks :help:
 Post subject: Re: 40 horse
PostPosted: Tue Oct 07, 2008 8:10 am
Brian, AKA (mk-zero) is our resident engine expert but there are more than one of us that could help you out. Like I said before, sounds to me like your crank end play may be out of wack, did you build the motor? This is for the 64 right?
PostPosted: Tue Oct 07, 2008 8:56 am
I had some guy out in PHX do the build . I called the guy that built it and he said that my case is just worn which maybe the case but he would take a look at it this coming Friday ! I have another motor that I have to go pick up in cali when I get my bus,so I may just reseal the good used motor and cruise that for the mean while. I may have to have "Brian" check my motor out also. Thanx for the support !
PostPosted: Tue Oct 07, 2008 9:04 am
Brian is out in Orange county now, but if you have any questions he can answer them(usually)
PostPosted: Tue Oct 07, 2008 10:20 am
Maybe if he's able he can check it out when he returns ?
PostPosted: Tue Oct 07, 2008 10:22 am
He lives out there now, but we can get that engine apart and mike out the bearing journals, and if we have any more questions, send him a P.M.
Brian, any ideas?
PostPosted: Tue Oct 07, 2008 10:25 am
I know the answer, time for a bigger engine! :hillbilly:
PostPosted: Tue Oct 07, 2008 10:27 am
I love 40 horse motors. I'm a stock Nazi.
PostPosted: Tue Oct 07, 2008 10:29 am
Haha, i understand
PostPosted: Tue Oct 07, 2008 10:34 am
i've always have kept my cars stock. My 64 is still six volt and is a DD.
