It is currently Thu Dec 18, 2025 2:17 pm
Post new topic Reply to topic  [ 45 posts ]  Go to page 1, 2, 3, 4, 5  Next
 Post subject: Engine breather kits
PostPosted: Fri Aug 14, 2009 6:52 am
My engine breather kit arrived yesterday. I was contemplating where I was going to mount the collection box. I see most are mounted on the firewall. I was thinking about mounting mine of the front of fan shroud. Any opinions?
 Post subject: Re: Engine breather kits
PostPosted: Fri Aug 14, 2009 8:10 am
I have mounted them on the fan shroud before, IMO you need to drill the hole then tack in a couple of nuts like the coil, mine kept vibrating loose when i just used screws.
PostPosted: Fri Aug 14, 2009 8:39 am
Thanks for the suggestion Ethan :thumbs: . I was thinking of tapping the holes. If I go that route, the addition of some Loctite on the bolts might take care of the vibration problem.
PostPosted: Fri Aug 14, 2009 8:50 am
Ben the fan shroud metal is to thin to tap out, you might be able to get some self tapping screws but over time i dont think you will be happy with the end result. It will pull out.
PostPosted: Fri Aug 14, 2009 8:51 am
Another good suggestion Ryan. Never thought about that. Back to the drawing board.
PostPosted: Fri Aug 14, 2009 8:55 am
I would stick with the traditional firewall mounting.....
PostPosted: Fri Aug 14, 2009 9:01 am
I hate to have to drop the engine just to mount the collection box. This might be my best option though.
PostPosted: Fri Aug 14, 2009 9:02 am
you dont have to drop the motor to install it. I had mine out when we were at Joe's for the party.
PostPosted: Fri Aug 14, 2009 9:05 am
I think you have a 36hp shroud? I have a standard shroud and it doesn't have hardly any room near the top to get back at the firewall. That is why I have been looking at other options.
PostPosted: Fri Aug 14, 2009 9:33 am
Are you gonna take that beast down the track? ;)
