It is currently Tue Nov 11, 2025 1:40 am
 Post subject: Rebuilding Bottom End. What Specifics Do I Need?
PostPosted: Fri Feb 07, 2014 3:38 pm
I am planning on rebuilding my old 1776 and I am wondering what specific tools will I need. Calipers, mics, special wrenches, etc.?
It was leaking a lot and I figure that since I have it out that I should go through the whole thing and replace things as needed and build it how I want.
Thanks!
 Post subject: Re: Rebuilding Bottom End. What Specifics Do I Need?
PostPosted: Fri Feb 07, 2014 4:26 pm
Chisel_86 wrote:
what specific tools will I need? Thanks!
Kostya's phone number
No, really. Flywheel lock, scale, good inside and outside diameter micometer. 90.5 piston ring compressor. Patience. assembly lube. Engine stand and VW adapter. Tourque wrench thats been calibrated. Case splitter, oil pump remover. Dist gear setting tool maybe. The how to build video is good. the how to hot rod book is good
I had a friend in Sac that would build motors using just ordinary hand tools. It can be done, and he used to win burnout contests in Vallejo, and drive back to sac and drive it daily. I wouldnt let him build me an expensive motor but people used to do it not checking any tolerances at all, just slap things together. That would be the differance between building an engine and slapping one together, I would suppose
good luck
PostPosted: Fri Feb 07, 2014 7:03 pm
When you are ready let me know I have every tool that you will need unless you plan on buying them.
