It is currently Thu Nov 27, 2025 3:53 pm
 Post subject: Sealing
PostPosted: Sun Nov 16, 2008 12:49 pm
I was resealing my trans and the diff fell out causing one of my sideplate gaskets to rip. Should i just got ahead and order a new seal kit or has anyone had any luck sealing using just form-A-Gasket RTV
 Post subject: Re: Sealing
PostPosted: Sun Nov 16, 2008 2:05 pm
Ill have to buy another seal kit anyways to get the endplay correct for the axles.
PostPosted: Sun Nov 16, 2008 5:23 pm
i might have a bunch of them gaskets..tell ethan to call me and ill check as im running out the door
PostPosted: Sun Nov 16, 2008 6:43 pm
well i did not have a chance to look..i realy was running out the door...ill be home tommorrow evening...call and ill look...they should be on my work bench though since i just assembled my tranny not too long ago..
PostPosted: Sun Nov 16, 2008 6:58 pm
I have some of them we bought a couple of sets when we did mine
PostPosted: Sun Nov 16, 2008 7:26 pm
good someone will have some for him..it only takes a few...hell mine only took one on each side
PostPosted: Sun Nov 16, 2008 9:17 pm
Cool i really appreciate it, mine only came with 1 extra after i put the 3 you start with on. So didnt even attempt to shim it.
