It is currently Mon Oct 06, 2025 3:11 am
 Post subject: How do you get the brass bushing out?
PostPosted: Tue Dec 15, 2009 9:39 pm
The one on the pasenger side on the throw out bearing shaft? :help:
 Post subject: Re: How do you get the brass bushing out?
PostPosted: Tue Dec 15, 2009 9:58 pm
Grind it out carefully...
PostPosted: Tue Dec 15, 2009 10:31 pm
I thought of that, why did you not say that when you were over here? There has to be another way or a tool.
PostPosted: Tue Dec 15, 2009 10:37 pm
After thinking about it on the way home, I figured the only way to get it out was to grind it out with a Dremel till it gets thin enough to collapse it/drag it out.
PostPosted: Wed Dec 16, 2009 6:01 am
if its a blind hole bushing they do make removal tools for most
PostPosted: Wed Dec 16, 2009 6:38 am
I have a Dremal but may not have the right grider bit. If you need it.
