It is currently Thu Nov 27, 2025 3:53 pm
 Post subject: CRANK WALK
PostPosted: Wed Apr 07, 2010 2:51 am
HOW BAD IS THIS? I was told that the crank walk moves back and fourth and caused the seal to break. the transmission was held to the motor by one bolt. what should I do with the crank walk? Thanks in advance.
 Post subject: Re: CRANK WALK
PostPosted: Wed Apr 07, 2010 5:28 pm
sounds and looks like you need someone to check the endplay on the crank it may be a new case is in order
PostPosted: Wed Apr 07, 2010 9:05 pm
I would tear the motor down and take the case to your favorite motor guru and let them inspect it. It may need the case thrust cut and new bearings installed.
PostPosted: Sat Apr 10, 2010 4:57 pm
It's seem like the local guy don't know what to do. he delays me to a different day each time I call to check on My ladybug. It's spring and no Bug Boohoo.
PostPosted: Sat Apr 10, 2010 9:58 pm
You need to take it to the wizard.
PostPosted: Sun Apr 11, 2010 7:10 pm
X2....take it to John!
