It is currently Mon Oct 06, 2025 3:08 am
 Post subject: Strange tranny sound
PostPosted: Sun Apr 24, 2011 2:21 pm
After fixing the steering wheel to steering box problem, I dropped the 66 off the blocks and backed it out of the garage. I went to shift it into first and had a bit of a problem getting it into gear. When I started to accelerate, a loud pitched noise came from the tranny. It sort of sounded like grinding but after a second or two, the noise disapeared and off we went. I drove it into town and just about every time I had to shift into first, it made the same noise. I wouldn't say it was like grinding into gear. It was more like a high pitched sound.
I thought maybe my shifter was off but after some adjusting today, it is still making the same noise. It is strange that it went from not making this noise before I parked it and had to fix the steering to now making this noise. I know it is not steering related but the point is that it sat for two weeks and then started making this weird noise.
Any suggestions?
 Post subject: Re: Strange tranny sound
PostPosted: Sun Apr 24, 2011 5:48 pm
maybe its a lubricating issue ?
may want to check the gear oil level in the transaxle to make sure its full
PostPosted: Sun Apr 24, 2011 6:05 pm
Bad throwout bearing ? does it go away when put the clutch in?
PostPosted: Mon Apr 25, 2011 5:01 am
It only does it when I start out accelerating in first gear :? .
I will give it a look. Thanks!
