It is currently Thu Nov 27, 2025 3:55 pm
 Post subject: Grinding when going into gear
PostPosted: Fri May 27, 2011 8:32 am
What would cause grinding when going into first or reverse? Also, it's hard to get the car into gear - but it doesn't pop out once in gear. Is it simply a clutch cable adjustment?
 Post subject: Re: Grinding when going into gear
PostPosted: Fri May 27, 2011 9:22 am
Have you tried adjusting the shifter plate to the floor pan? It could be that it is not in its correct location.
PostPosted: Fri May 27, 2011 9:43 am
sOunds like clutch
PostPosted: Fri May 27, 2011 10:12 am
Could be fluid; have you changed the fluid and is it full?
Could be clutch adjustment; is there about 1.5" of play?
As Ben has stated; is the shifter adjusted properly?
What about the shift rod bushing and shift rod coupling? have those been inspected and changed if needed?
PostPosted: Fri May 27, 2011 11:32 am
I don't know to all of these. This is a good place to start, thanks guys!
