It is currently Tue Dec 02, 2025 11:04 pm
Post new topic Reply to topic  [ 24 posts ]  Go to page 1, 2, 3  Next
 Post subject: License plate restoration
PostPosted: Sun Oct 16, 2011 8:28 pm
I am starting a thread here to keep info straight.
It seems that the restoration process is a closely guarded secret. Everybody can figure out how to paint the plates, but can't figure out how to paint the numbers so they look good.
A couple of us have been trying and have been doing some research. Hand painting works, but its not perfect and doesn't look "Factory".
I watched a vid on YouTube on the "How to" process. I think it was the only one. It was filmed by some geezer. Cut to the chase, he silk screened the numbers on them. Chris was hinting at this process was was gonna ask a buddy about it.
I thought I had it figured out, and I think I am close, but I need to research paint/ink compatibility. I am speculating the "Factory" did it like a printing press. They pressed the plate into ink/paint and that was that. So here is what I did...
I bought a vinyl floor tile for my press base. I marked where the edges of the plate would be with a sharpie marker. This defined where I would lay the paint. I used a cheapo $1.99 roller that had a blister pack that doubled as a paint tray. I spread the paint (Rustoleum Oil Base Enamel) onto the tile. I then pressed the tile into the paint and flipped it over. It ALMOST worked. I didn't get even coverage and I had to make sure I was pressing all the numbers hard into the paint. It didn't leave an even amount of paint on the raised sections. If the paint was too thick it drooped a little bit, almost running.
But yall can now see the "Printing Press" vision I have...
In further contemplation of the situation and a trip to Michael's....
I think I need to use a thicker paint. I came to this conclusion watching the silk screening process. That Ink is thick like paste. The ink that was sold at Michael's was a water base ink. It used for silk screening shirts. I'm not calling it paint. I'm not sure of the difference anyway...
So the question arises, Can I use this "Ink" on top of an oil based enamel?? I was planning on clear coating when I was done. I guess I could experiment, but maybe some one knows of a thicker ink/paint that would work. I think the technique will work and be easier than "Silk Screening"
Ideas? Comments? I need yall to shoot holes in this idea. I have repainted my plate 3 times already, Next time WILL be the last time!
 Post subject: Re: License plate restoration
PostPosted: Sun Oct 16, 2011 8:42 pm
Dude you should video tape it when you figure it out so you can post it on youtube. Keep us posted because I was very curious about it.
PostPosted: Mon Oct 17, 2011 8:54 am
I've wondered myself...
PostPosted: Mon Oct 17, 2011 10:58 am
Have you thought of using vinyl? Cutting out the negative space and using paint? Much like masking when your airbrushing. It will give you cleaner lines and you can clear coat afterwards. The coating should last for years
The set up is what is going to take time, because if you are cutting the mask by hand. If you don't want to cut the mask by hand, scan the plate create an .eps and a person with a vinyl cutter can cut it out.
PostPosted: Mon Oct 17, 2011 8:07 pm
It crossed my mind to do something similar, but then I would not be able to do anybody else plates easily.....
PostPosted: Mon Oct 17, 2011 8:09 pm
Have you seen this? Fiberglass and airbrush...
http://tagdr.com/procedure
http://www.tcpglobal.com/airbrushdepot/ ... 7AodGCF0AA
Also, I saw somewhere recently that additives can be added that allow paint to 'flow'. Seems like it was for painting cabinets and whatnot so the brush marks evened out.
I think this is what they were talking about:
http://www.flood.com/paint-additive-sol ... oductId=11
PostPosted: Mon Oct 17, 2011 8:12 pm
Hand Painted alphanumerics.....
Im good, but not great. They have a guy on the pay role just for that.......
PostPosted: Mon Oct 17, 2011 8:15 pm
Probably a sign painter by trade. Hey, that's how 'True Fire' Mike Lavallee got started.
PostPosted: Mon Oct 17, 2011 8:42 pm
I have a laser, I can try to make an adhesive mask right over the plate, then it can be painted. I am not a good painter, but I can cut the mask out and then you can paint it, remove the mask and add several coats of clear. That would make it last for some time, just like the paint on your car.
I can try it on some plates I have in the garage to see if it will work.
PostPosted: Tue Oct 18, 2011 8:40 am
Something like this:
[youtube]http://www.youtube.com/watch?v=7jb8IvCaGdc[/youtube]
