It is currently Fri Oct 17, 2025 6:15 am
 Post subject: Seat Belt
PostPosted: Fri Dec 05, 2014 2:53 pm
1959 bug do not have a seat belt and I would like to add it in.
Any tip to make one?
Pic?
Measure?
:help:
 Post subject: Re: Seat Belt
PostPosted: Fri Dec 05, 2014 4:38 pm
very simple drill two holes in your pan and mount them, or take the carpet back out and weld a nut to the tunnel and drill the other hole through the pan. in this picture you can see where my seat belts where added in to my 61 pan
just follow the belt to the pan
in this picture you can see the eye hooks the person used to install them. There is no standard spot buy some belts and go to town no wrong or right way.
PostPosted: Thu Dec 11, 2014 2:48 pm
What doesn't Ethan know?!?!? :)
PostPosted: Thu Dec 11, 2014 4:31 pm
a lot :hillbilly: :(
PostPosted: Fri Dec 12, 2014 7:49 am
I'm adding seatbelts on my 63. In that year they had the holes (unlike yours). However, since my pans are replacements I have to drill a hole. I went ahead and got some weld in seat belt plates from CIP1 https://www2.cip1.com/ProductDetails.as ... -20304-SET. You drill a hole through the pan, then weld the plate on the bottom of the car.
Here are some pictures to help you get an idea of placement.
http://images.thesamba.com/vw/gallery/pix/955020.jpg - where the round plastic tab is
http://www.jbugs.com/product/ZVW20-RETRACTABLE.html - pictures at bottom of page
