It is currently Tue Dec 02, 2025 10:59 pm
 Post subject: how do adj brakes
PostPosted: Tue Apr 10, 2012 2:21 pm
On a 68 bug, what is the correct way to adj. the brakes. I heard you adj. the bottom first then the top. do you tighten untill drum doen't turn aqnd the loosen????
 Post subject: Re: how do adj brakes
PostPosted: Tue Apr 10, 2012 3:56 pm
I'll let the brake experts chime in since I'm not fast enough for them.
But one question, top adjustment...what the heck is that?
PostPosted: Tue Apr 10, 2012 4:28 pm
Dual wheel cylinders?
PostPosted: Tue Apr 10, 2012 4:36 pm
On a '68?
PostPosted: Tue Apr 10, 2012 5:03 pm
supaninja wrote:
On a '68?
PostPosted: Tue Apr 10, 2012 5:04 pm
Never mind I had bus on the brain....
PostPosted: Tue Apr 10, 2012 5:21 pm
I don't know if it's right or wrong but it works. Adjust top till wheel don't turn then back off just a hair and I meen just a hair untill it turns then do the same with the bottom. The trick is they will be realy close or it will seem like it will never bleed. Good luck.
PostPosted: Tue Apr 10, 2012 7:45 pm
I didnt know that a 68 has a top and bottom adjuster.
PostPosted: Tue Apr 10, 2012 7:50 pm
i dont remember if my 69 did or not....the key is to get the pads realy close...i even let mine rub just a little on the top and bottom....just a little is the key that way i know they are close...they wont rub long after you start driving it....
PostPosted: Wed Apr 11, 2012 4:23 am
69 only has the bottom adj. Maybe Bo remembers on his old 68..
