It is currently Tue Dec 02, 2025 10:59 pm
 Post subject: IRS wheel bearings...
PostPosted: Mon Apr 14, 2014 9:35 am
To change the IRS (rear) wheel bearings, do you need to remove the stub axle from the arm?
 Post subject: Re: IRS wheel bearings...
PostPosted: Mon Apr 14, 2014 11:05 am
Looks like it. Dang.
Thanks Wayne. :thumbs:
PostPosted: Mon Apr 14, 2014 3:50 pm
Post up some pics. I haven't had any experience with late model suspensions.
PostPosted: Mon Apr 14, 2014 4:13 pm
I've been hearing a whirring/slight groaning noise durring decelleration and on freeway ramps while turning left. No noticable noise at slow speeds. Wayne had suggested that it may be the CV's or the bearings. I know my axle nuts are tight. It sounds like too much to do before the classic so I am going to just take it easy. It's not a horrible noise.
What I think I'll do, is buy new bearings in case I need them, and install new 944 axle shafts when I do my conversion sometime in the future. I have all the other parts I need. I'll post up when I get around to working on it.
PostPosted: Mon Apr 14, 2014 7:17 pm
Upon further diagnosis, I believe the sound is coming from the front passenger side. Noticeable from 45mph and up. Now I have already checked the bearings and hub up there since I was having other brake issues. I will have to check the rest of the suspension. I'm quite baffled about this now. It does it when I'm slowing down and also when turning left...
PostPosted: Mon Apr 14, 2014 7:30 pm
I had a noise like that in my 69. Turned out to be the cv.
PostPosted: Mon Apr 14, 2014 8:31 pm
I need a pro with good ears to ride along with me.
PostPosted: Tue Apr 15, 2014 3:37 pm
Still stumped about this. I've repacked and tightened the front bearings and replaced the pads.
Could an over-tightened rear axle nut cause this?
PostPosted: Tue Apr 15, 2014 6:35 pm
I've decided to drain and refill the trans fluid. It couldn't hurt since I've never done it... (Ducks head down in shame...)
