It is currently Sun Apr 28, 2024 3:52 am
 Post subject: ghia wiring
PostPosted: Wed Aug 10, 2011 4:50 pm
I have a 70' ghia with a brand new wiring harness, from karmann ghia p&r.... I have everything wired up and working but there are still a few kinks, like the battery will not stay charged.. I'm no electrician, so I just did the best I knew how. Is there anyone out there that knows what they are doing with wiring.? I know it should be simple and I'm willing to pay for the work. I just want everything to operate correctly.. If anyone is interested in helping a fellow dub'r hit me up. 214-542-0691
 Post subject: Re: ghia wiring
PostPosted: Wed Aug 10, 2011 5:03 pm
you can probably fix it yourself. Are you using a alternator or generator?
PostPosted: Wed Aug 10, 2011 8:45 pm
I would first check for a draw on the batter when nothing is on.
to easily do this just disconnect the negative side and see if you get a spark when you touch the cable to the battery, I usually drag it across and make sure its dark so you can see any slight spark. if there is a spark thats the problem
then remove one fuse at a time until the spark goes away, when the spark goes away you have found the circuit in which the load is being applied to the battery.
PostPosted: Thu Aug 11, 2011 7:53 am
Most of the time its some sort of grounding issue :thumbs:
PostPosted: Thu Aug 11, 2011 8:29 am
if it's an alternator conversion and the wiring wasn't changed properly then it won't charge...real simple fix too.
PostPosted: Mon Aug 15, 2011 1:07 pm
Thanks guy.. ;) It is an Alt conversion.. I did remove the external regulator, but I don't know what other wiring may need to be changed for that.. I will go home and try the neg- cable test and let you know..
PostPosted: Mon Aug 15, 2011 1:27 pm
you need to finish the alt conversion, blue and green wires at the voltage regulator needs to be spliced together.
PostPosted: Mon Aug 15, 2011 1:31 pm
I did splice the blue/green together.... I'm now thinking it is gonna be a ground some where... thanks for the help...
