It is currently Tue Dec 02, 2025 10:59 pm
 Post subject: Weird Electric
PostPosted: Sun May 19, 2013 7:12 pm
I had 3 miles left to go home but broke down. Half of the electric work and the other half is not working. I've been looking around for over 10 min and got nothing. Made a phone call for help and then all the electric came back on. Started the motor and wouldn't start. So, I went ahead and fixed the point again and the motor starts up and made it home. Any idea why it doing it? :help:
 Post subject: Re: Weird Electric
PostPosted: Sun May 19, 2013 7:37 pm
Peoples choice award !! it's a bug... in the bug.
PostPosted: Sun May 19, 2013 8:52 pm
Are you burning up points ?
When you say half works what stops working exactly?
PostPosted: Mon May 20, 2013 8:30 am
w:pw
PostPosted: Mon May 20, 2013 8:35 am
The Points is not burning, guess it off. Going to throw point and put electronic.
The electronic ignition, oil light and temp light not working. headlight work fine.
PostPosted: Mon May 20, 2013 9:06 am
Ignition switch?
PostPosted: Mon May 20, 2013 10:15 am
Ignition switch?
Guess it time to buy a new Ignition switch.
PostPosted: Mon May 20, 2013 11:43 am
Redjames wrote:
Ignition switch?
That was just a guess, I wouldn't buy one just yet... Check your connections first, maybe one is loose.
PostPosted: Mon May 20, 2013 1:07 pm
Check the fuse panel....cracked, see if you have power at each fuse
