It is currently Tue Nov 11, 2025 3:42 am
 Post subject: Front Air Shocks to help with ride quality???
PostPosted: Sun Nov 18, 2012 5:27 pm
I have 2.5" lowered spindles, 2" narrowed beam and adjusters with std. KYB shocks. The ride is harsh. Will a set of Monroe MA700 air adjustable shocks help with ride quality? My current setup has the front sheet metal about 4.5" off the ground. I like the lowered look, but I'd also like a better ride.
Thanks in advance,
 Post subject: Re: Front Air Shocks to help with ride quality???
PostPosted: Sun Nov 18, 2012 5:32 pm
Ball joint or link pin?
PostPosted: Sun Nov 18, 2012 5:33 pm
You are going to want an oil filed shock. Not gas.
PostPosted: Sun Nov 18, 2012 5:37 pm
If its Link pin take the shocks off and see how it rides.
PostPosted: Sun Nov 18, 2012 6:07 pm
I think his is ball joint... 1970 I think . I've been thinking of air shocks myself but to raise it up about 1/2 inch. I too have KYB and the ride is stiff but ok. I would like to know what you find out ...
PostPosted: Sun Nov 18, 2012 6:18 pm
71 Beetle, Ball Joint.
PostPosted: Mon Nov 19, 2012 12:10 am
People always complain about the KYB gas shocks making the ride too harsh, just run some oil shocks and I'm sure it will feel a lot better. I wouldn't bother with air shocks unless you need more ground clearance and your beam is already adjusted all the way up.
PostPosted: Mon Nov 19, 2012 5:33 am
Thanks Bryan ... considering air shocks.. I also have read that the ride, if not pumped too much, is a nice ride.
Bill, sounds like your ride heigth is good .. I would try the oil shocks.
PostPosted: Mon Nov 19, 2012 7:53 am
Have a Air shock for 2 year and it fine to me. But I don't how it feel with either gas or oil shock cuz I have not try it.
PostPosted: Mon Nov 19, 2012 10:56 am
Just for grins, what brand, what model of oil shocks that will fit my lowered front end???
Thanks,
