It is currently Mon Apr 29, 2024 5:59 am
Post new topic Reply to topic  [ 18 posts ]  Go to page Previous  1, 2
 Post subject: Re: Beam Height Adjustment Probem(s)....
PostPosted: Sun Dec 16, 2012 9:04 pm
Here is a picture of my beam as delivered....should show detail of adjusters that were factory installed (guess that still doesn't make them absolutely correct).
Image[/url][/img]
The question still stands, what if the upper or lower arms don't rotate freely??? Remove and rebuild???
Thanks again for all your help....
PostPosted: Sun Dec 16, 2012 9:13 pm
If after removing the adjusters they don't rotate freely I would suggest removing the spindles and see if both are hard to move or if they are fighting each other
PostPosted: Sun Dec 16, 2012 9:20 pm
The adjusters look like they are not indexed the same? They may be fighting each other.
PostPosted: Sun Dec 23, 2012 7:45 pm
Well here's the latest. The beam that I had built at Car Craft in Riverside, CA had the incorrect beam for the 2-1/2" dropped spindles!
Should have been EMPIs 2" narrowed beam for dropped spindles with ratchet-style adjusters that the normal height grub screw is right in the middle of the adjuster lock with the ability to raise or lower the front of the car 1/2 of the overall allowable movement...
Also CB Performance has a US made set of torsion leaves that are softer than most of the aftermarket leaves and should give a near stock spring feel. I'm checking with them to see if their leaves will work with the EMPI narrowed beam.
More info as it becomes available.
PostPosted: Sun Dec 23, 2012 8:33 pm
This is why I never trust anyone to build me anything. People are idiots.
PostPosted: Sun Feb 03, 2013 7:05 pm
Well, I'm finally on the road again. Rebuilt the beam with "Sway-A-Way" style adjusters, new lowered style ball joints and the CB Performance Products 10% softer torsion leaves. (see pics)
I also put on a set of KYB Excel G shocks. The front end is now lowered with the front apron sheet metal about 4-3/4" off the ground. Looks good, not too low, not too high.
So far the ride is just about like stock. I have also ordered a Whiteline "Over The Top" front sway bar. Should be in tomorrow. Just couldn't make the typical sway bar work as low as it is.
More pics on Wednesday.....
PostPosted: Sun Feb 03, 2013 8:08 pm
Glad you got it figured out man.
PostPosted: Sun Feb 03, 2013 8:20 pm
Looks good Bill!
