It is currently Tue Nov 11, 2025 1:45 am
 Post subject: chasis and airbags
PostPosted: Sat Apr 26, 2014 6:40 pm
I have a 74 super beetle that needs some rust work to the front of the chasis .what's the easiest way to fix ? And I am looking for a airbag kit .. any advice on brands or kits ? Im Trying to do this on a very low budget
 Post subject: Re: chasis and airbags
PostPosted: Sat Apr 26, 2014 7:33 pm
Hey there!
If you want airbags AND low budget, you're best off designing your own setup if you've got access to the right tools. If you wanted to purchase a kit I think the most common one is from Airkewld. But he's not the cheapest guy around and I don't know if he has a kit for super beetles. If you went with a static drop, you could install drop spindles and adjust the rear.
PostPosted: Sat Apr 26, 2014 10:05 pm
I think airkewld has a Super airstrut. They don't make drop spindles for Supers of any year. Too many tie rod and ball joint issues.
