It is currently Tue Dec 02, 2025 10:07 pm
 Post subject: Alternator Backing Plate
PostPosted: Mon May 07, 2018 7:37 am
I wasn't sure whether to put this here or in the Tech Help but thought more people might see it here.
I'm in the process of rebuilding my 2110 and while I'm at it I'm putting on my chrome alternator and welded fan. My question is, does anybody make a better quality, possibly billet aluminum backing plate? I run a DTM fan shroud on mine but it uses the standard backing plate. I've searched around and so far only find the stock black or chrome plates.
Help!!!???
 Post subject: Re: Alternator Backing Plate
PostPosted: Mon May 07, 2018 8:54 am
Back in the day there were aluminum ones, you may be able to find a used one on the samba or ebay. I had one at some point... long gone.
PostPosted: Mon May 07, 2018 12:04 pm
Good to know there's at least a possibility. I'd been looking on both ebay and the samba and had pretty much given up.
PostPosted: Thu May 10, 2018 3:50 pm
http://www.cbperformance.com/product-p/2177.htm
PostPosted: Fri May 11, 2018 8:57 am
I missed that one in my search somehow. CB was the first place I looked but must have had a momentary ID10T issue. :D
Thanks Tommie.
PostPosted: Fri May 11, 2018 9:19 am
Wow, and it's TURBO! :wow:
That ought'a add at least 50 hp :P
PostPosted: Fri May 11, 2018 11:10 am
Exactly!!!!! :D :thumbs: :beer: :dance:
PostPosted: Fri May 11, 2018 1:50 pm
I had one Chromed once.. it added 20% HP .. I don't know if that was exact.. I think it was more like 18% ? but that is what I was told.. should of Dynoed before and after to see what the real result was?
:shock:
PostPosted: Fri May 11, 2018 3:09 pm
:shock:
I run a chrome one, how do you think I got to 230+ hp? :P
PostPosted: Mon May 14, 2018 8:00 am
If I'd have known that's all it took to turbo a motor, I'd have done it years ago. I'd heard the cost was WAY higher than that. :D :D
