It is currently Sun Apr 28, 2024 11:27 am
 Post subject: Car Lift
PostPosted: Thu May 10, 2012 8:37 pm
My grandfather was a mechanic for over 50 years, he's now retired. He's selling one of his lifts that is only about 5 years old. Looks like the lift above. If you're seriously interested, I can get more info for you. It's located outside of Orange, Tx, you'll have to go pick it up. He might be able to help take it down, prob can't help you load, he's 80. The lift has seen very little use. For the last 3 years the only thing it has lifted is his Cadillac. He's asking $2800. Let me know if you want more info.
 Post subject: Re: Car Lift
PostPosted: Fri May 11, 2012 8:01 am
Eliot? You know the shop could use one of these.. :shock:
PostPosted: Fri May 11, 2012 1:29 pm
i know he wants one that would fit nice in the shop.
Lucky's Fab Shop
Specilizing in Rack and Beams
facebook.com/luckysfabshop
PostPosted: Fri May 11, 2012 1:47 pm
What make and model?
PostPosted: Fri May 11, 2012 5:06 pm
I'll have to call and ask him to check. If you're serious about buying, I'll call him. If you're curious, just guess.
I'll call and ask him to check, might be a few days before he gets back to me. For being almost 80 he actually stays really busy.
PostPosted: Fri May 11, 2012 7:39 pm
My new shop could sure use one. Where is it located?
Jason Wallace
smgpsinstall.com
1966 Vert ( My Driver )
PostPosted: Fri May 11, 2012 7:48 pm
Orange County, Tx, about 2 hours from Houston.
PostPosted: Fri May 11, 2012 7:49 pm
Here's the model: http://www.qualitylifts.com/auto-lift-e ... e-lift/Q10
10,000 lb Capacity 2-Post Lift
ALI/ETL Certified
Lifting Capacity 10,000 lb.
Max Load per Arm: 2,500 lb.
Higher Rise with 71" Stroke Cylinder
Rise Height of 78.75" Provides Excellent Underneath Clearance
Adjustible Overhead For Max Clearance or Protection Against Lower Obstructions.
Height Overall: 12 '3 1/2" or 11' 5 1/2"
Width Overall: 131 3/4"
Drive Thru Clearance: 98 3/8"
Padded Overhead Safety Switch
Floor to Overhead Limit Switch: 11' 8 1/2" or 10' 10 1/2"
3-Stage Front Arm and 2-Stage Rear Arms.
Symmetric or Asymmetric Lifting.
Front Arm Reach: 21 3/4" - 39 1/4"
Rear Arm Reach: 38 1/4" - 55 3/8"
Double Telescoping Screw Pads.
Optional Drop In Truck Adapters
Screw Pad Height: 4" - 7 1/2"
Inside Columns: 110 1/4"
Full Size Cables and Steel Cables for Longer Life
Single Point Lock Release
Rubber Door Protector
Powder Coat Paint Blue
Motor: 2HP
Voltage Single Phase: 208-230v Standard
Ceiling Height Required: 12' 5"
PostPosted: Fri May 11, 2012 7:53 pm
He'll negotiate on price, but not a ton.
PostPosted: Fri May 11, 2012 9:12 pm
you can buy the same lift brand new for cheaper. just saying ;)
https://www.directbuyautomotiveequipmen ... category=5
Users browsing this forum: No registered users and 57 guests
