Well I got the inside unit mounted for good. all I have left is to cut the trim board and a little touch up paint.
Inner hole (I was an 1/8 from a stud)
outer hole
on this unit you can switch what side the drain hose comes out so I switched it. I also got the spring in place and ready to make the 90 degree bend down the wall.
all that is left is making the bend,shorten the line set, and final hook up and vacuum. I steel need to pick up a nice lineset cover.
final install on inner unit.
Some of you may be wondering why I didnt put the trim board in the center. Well that was a slight screw up I did center and level the bracket using the seam where the two pieces of plywood come together. Only thing I did not check was the unit is offset to the bracket by 3 or 4 inches to the right, I noticed it after I first hung it on the wall. O well
