It is currently Mon Oct 13, 2025 5:57 am
Post new topic Reply to topic  [ 49 posts ]  Go to page 1, 2, 3, 4, 5  Next
 Post subject: Work Day on Mike's 60 Vert
PostPosted: Wed Oct 13, 2010 8:38 pm
Ok, so here's what's going on this weekend. Me and Mike are going to drag his 60 Vert over to the shop tomorrow. The plan is to work on it Friday night and Saturday afternoon. Hopefully we can get that biatch back on the road for Ft Worth so Philly will have someone to ride with :redguy:
 Post subject: Re: Work Day on Mike's 60 Vert
wish I could make it but I am not allowed in Dallas
PostPosted: Wed Oct 13, 2010 8:41 pm
:lol: :lol: for some reason I don't doubt that :beer:
PostPosted: Wed Oct 13, 2010 8:43 pm
:lol: :lol: :lol:
PostPosted: Thu Oct 14, 2010 12:54 am
Right on!! Thanks guys!! :thumbs:
PostPosted: Thu Oct 14, 2010 1:16 am
Hey guys.....Painfully, I've found out that I have to work on Saturday. Also, my kiddos have soccer games in the morning, then I'll have to work until about 7 or 8pm. However, I'll be free all day today, Friday, Saturday after 8pm and all day Sunday. I apologize for the short notice. However, I do welcome anytime anyone is willing to give!! ;) Thanks for stepping up!! :thumbs: :thumbs:
PostPosted: Thu Oct 14, 2010 1:39 am
Hey Ethan, I ran into pc issues last night and wasn't able to post pics. I was taking these with my phone and try to get the best angle I could.
Vin showing true year
Cupler....
Pic with stock shifter in....
I'll fix the sizes tomorrow...it's late and I'm hittin the sack
PostPosted: Thu Oct 14, 2010 5:33 am
I can come by the shop today after 3:00pm. What time
are you picking up mike's vert? I have some parts for
Brandon's ride!!! See you guys later!!!! :thumbs:
PostPosted: Thu Oct 14, 2010 11:29 am
I think I had some of the same problems you are having when I got my 60. Sloppy shifting and ocassionally the shifter would physically spin around. What it turned out to be on mine was for a 60 you should have a 36hp with a split case transmission. If someone has in the past adapted a tunnel trans in it, they had to use a different nose cone and hockey stick.
Qoute from Bill May on Samba when he was helping with my issue
when a splitcas trans is replaced with a tunnel case it is done using a bus nosecone and hockey stick. a bus has its coupler on bottom of hockey stick instead of on top like a beetle-i am talking about the detent for the coupler set screw. if it is not drilled in correct location it will twist coupler out of alignment and cause exact problem you are having. i think the detent is not in correct spot as it should be drilled to adapt the hockey stick(bus) to the coupler(beetle and bus) and shift rod is twisted out of alignment.--- fix=?? replace hockey stick or redrill yours in correct spot. 180 degrees from original bus location.
Complete thread http://www.thesamba.com/vw/forum/viewto ... sc&start=0
That wood screw in your coupler makes me think this is where your problem is gonna be at.
Mike Ehmann
1960 Beetle on bags
PostPosted: Thu Oct 14, 2010 5:48 pm
Great work nite! Kinda sucks... had to cut it short!! :redguy: Eliot's minature girraffe came in!! He said something about him havin opulence?!
