It is currently Sat Dec 06, 2025 12:36 am
Post new topic Reply to topic  [ 96 posts ]  Go to page 1, 2, 3, 4, 5 ... 10  Next
 Post subject: 36hp clown college engine build
PostPosted: Tue Jun 13, 2017 10:04 pm
Stay tuned for the most clueless 36hp build you've ever seen. I know nothing and have set out to prove it and maybe learn something along the way.
I'm either building a working engine or a nice looking expensive grenade... only time will tell, it's a waiting game.
 Post subject: Re: 36hp clown college engine build
PostPosted: Tue Jun 13, 2017 10:05 pm
Stay tuned
PostPosted: Wed Jun 14, 2017 8:32 am
Haha...clown college build! :D
You're gonna do fine, Eric. Engine assembly is nothing to fear.. It's not hard; only a little tedious. Be patient, get a manual or some advice on the critical steps, torques, and other specs (aka tommiebsmith), pay attention, keep things really clean, double-check everything, and stop and ask if you're not sure.
You got this!
Scotty
PostPosted: Wed Jun 14, 2017 8:59 am
PostPosted: Wed Jun 14, 2017 9:16 am
PostPosted: Wed Jun 14, 2017 1:22 pm
Good for you, you can do it, it's very much a series of steps that you do in a more-or-less particular order. Read as much as you can, there's plenty of info out there. :thumbs: :beer:
My biggest fear these days is the quality (or lack thereof) of bearings available. This is why I blueprint every single bearing when I build an engine, even the cam bearings. I've seen brand new bearings that are out of spec... and usually on the too-tight side of things, which is waaaay worst than them being a bit loose. Tight bearings lock up motors.
Anyway, if you have access to the equipment (bore gauges and micrometers), I *highly* recommend blueprinting all your bearings. I have a thread HERE that shows how I do things.
Good luck, let me know if there's anything I can do to help.
PostPosted: Wed Jun 14, 2017 6:35 pm
Thanks Scotty and MK!
That link will be super helpful. Hope Tommie has unlimited texts because I have been wearing them out :beer:
PostPosted: Wed Jun 14, 2017 8:37 pm
Day 1. Cleaning, mop mop all day long, mop mop mop while I sing this song.
So first rookie mistake was Brothers offered to sand blast the case, I said sure. Then later read don't ever do that. Ugh. They plugged the oils lines prior and really didn't hit much of inside. I asked them not to locktite the plugs. So I got the rifle cleaning kit out and cleaned it good.
Then ran a full bottle of carb cleaner thru it. Then ran the hose thru it for a long time. Neighbors love me.
I might actually shower with it tomorrow.
Probability of grenade 98.2%
File comment: What the heck does -4 mean
PostPosted: Wed Jun 14, 2017 9:38 pm
I now have a good understanding of how oils flows thru the case and how the system works
PostPosted: Wed Jun 14, 2017 9:48 pm
Tall boys have more displacement than a bus motor?
