It is currently Mon Apr 29, 2024 4:31 am
Post new topic Reply to topic  [ 33 posts ]  Go to page Previous  1, 2, 3, 4  Next
 Post subject: Re: 57 Streetrod Project
PostPosted: Sat Jan 10, 2015 7:54 pm
Work on pan continues. Edge of pan hairpin brackets/pan strengtheners are complete (not bolted on in this picture). Front suspension is almost done. Still have to work on the panhard bar and thread the hairpins to accept the rod ends and clevis ends.
PostPosted: Tue Jan 13, 2015 11:17 pm
Those clean clean coil overs :)
PostPosted: Sun Jun 05, 2016 9:30 pm
Spent the last months repairing most of the rust on the body. The heater channels were pretty much crap. All fixed now. Also repaired the lower half of the front firewall, a new lower right door hinge, a new right rear wheel well as well as the area from the heater channels to the center hump on both sides. I also replaced both rear "tail" pieces, the apron and both engine compartment side shelves. Still to put in is a new rear firewall (bead rolled by a local shop). I also cut and welded the sheet metal to form around and under the front hood (just don't like that open look).
I put the body on the pan and wheels & tires on to check the fit since all the body work was done...pretty well fit with only a couple of bolts to line up with the threaded inserts.
PostPosted: Mon Jun 06, 2016 10:30 am
Lookin good!
PostPosted: Mon Jun 06, 2016 1:51 pm
Looking good! I really like the piece you made to cover the outer heater channel, it really finishes it off.
PostPosted: Tue Jun 07, 2016 4:11 pm
real nice Bill..
PostPosted: Wed Jun 08, 2016 5:58 pm
I like the style :thumbs:
PostPosted: Thu Jun 09, 2016 7:06 pm
Thanks for the positive thoughts guys....it's been slow work. So many big and small things to fix and keep focus on the end look...I added the headlights (to make sure they would work and still be able to steer as well as making sure the fiberglass will work on the sides of the lower front side areas. I like this look, but still need to lower the rear end. Cut the rear firewall out today and started welding in the new bead rolled piece I had made. Pics when it's complete. Looking forward to July 10th! Love the SPLASH!!!
PostPosted: Sat Jun 11, 2016 8:34 pm
Lookin good!! :thumbs:
PostPosted: Mon Jun 13, 2016 8:02 am
What is your projected completion time ftame?
Users browsing this forum: No registered users and 52 guests
