It is currently Fri Oct 17, 2025 2:54 am
Forum rules
Please post your tech questions in the appropriate category.
Post new topic Reply to topic  [ 18 posts ]  Go to page 1, 2  Next
 Post subject: Torque Wrench question
PostPosted: Sun Dec 01, 2013 10:35 am
Picking up a torque wrench (250 lbs) and wanted to see which drive size was best? Does it really matter? I see they come in 3/8 and 1/2. Sears has killer deals on some of them so gonna order one tonight or tomorrow since i'll need it to torque my axle nuts back down
 Post subject: Re: Torque Wrench question
PostPosted: Sun Dec 01, 2013 12:28 pm
I prefer 1/2" for anything that requires substantial torque.
PostPosted: Sun Dec 01, 2013 12:29 pm
When you torque the axle nuts you can use 3/8" since it's only small torque while using the torque multiplier.
PostPosted: Sun Dec 01, 2013 12:40 pm
For that matter you can use a 3/8" torque wrench and torque tool even for an engine gland nut. In that case you can do pretty much anything on a VW with just a small torque wrench.
PostPosted: Sun Dec 01, 2013 6:28 pm
I have never needed anything more than the 3/8 one that I have.
PostPosted: Sun Dec 01, 2013 9:46 pm
I may go with the 1/2 size. When i get home tomorrow i will dblcheck what drive size the 36 mm socket is that i bought. A wrench capable of 250 ft lbs is enough for all the jobs needed for a vw right? Aircooled one, that is
PostPosted: Mon Dec 02, 2013 12:03 am
For big motors I torque the gland nut to more like 400+ ft-lbs, but I use a math and a cheater bar to get that. ;-)
PostPosted: Mon Dec 02, 2013 6:21 am
Math? where can I buy that?
PostPosted: Mon Dec 02, 2013 10:15 am
Math... They have that everywhere :) You just gotta ask for it.. as it rarely is on the shelf..
I use the torque dude thing also.. I put a little grease on the gear shaft that goes into the main piece for a little help with
friction on moving parts...
I have an old 1/2inch my Dad handed down.. but I would like a 3/8ths one myself..
Biggest thing is to take care of them..
PostPosted: Mon Dec 02, 2013 11:35 am
How does this math work? If I can get away with a torque wrench up to 150 ft lbs., then I will do so, but is there another tool needed to achieve/multiply the torque above the wrench's capabilities? I googled "torque multiplier tool" and it came up with some tools starting around $400-$1200!!
